AC unit for Fiesta Vee 250, 2005
YuriYuri Member Posts: 3
Please help me figure out dimensions of AC unit compartment for this model. Mine is shrink wrapped and on the storage but looks like I have good deal on AC. Not sure if I can fit it in.
  • rasburyrasbury Member Posts: 8,925 ✭✭✭✭✭
    if you can pull an owners manual for the fridge you have found, more than likely it will also include the installation guide which would give you all the dimensions...
    I think Ras meant the AC unit and not the Fridge.
    well I suppose......yep that's right!
    previous post was a fridge....
    @Yuri, most of the AC units are the same size for the number of BTUs. get that info and you should be very close in dimensions.
  • YuriYuri Member Posts: 3
    Thanks, I mean Air Conditioner. As an option they used to install 7000BTU unit, I am getting 9000. My concern regarding of width of the unit. I know it is tight and in a worst scenario I may do some extra openings under head sink.
    @Yuri. Was your unit made by Marine Air? If so, you should be able to google Marine Air and get a measurement for their 7000BTU units and see how that compares with a 9000BTU unit. You could even call the company. I have in the past and they were very helpful.
    Thank you Michael. It was made by Dometic but they don't have this information available anymore (from 2005). New 6000-8000btu models have depth only 10", mine is 15". I know there is some extra room, but not sure if so much.
