Speedometer not working
I went to use my boat this weekend and noticed the speedometer was not working. Not sure if it is a loose wire, fuse or something use I need to check. I have a 2014 Rinker 196 bowrider. I checked the manual and there was no info that helped. Any help or suggestions appreciated!!
Here it is. I got under the drive and the tube was pinched somehow. I cut it with a knife and reattached it to the yellow plastic fitting. Now I am trying to fix the trim sensor.
I guess if it is solid, go with it and see if it works out. You can always use a float or dinghy to get to something underneath if need be.
