Improving TV signal
All i have the Shakespeare pizza dish think it's 10" or so. Also have the signal booster in the TV center.
Need to up the signal strength as I have frequent losses of signal (picture pauses for a second or so).
I'm going to redo all the connections when I get the boat back from storage.
Was wondering if I should change components. The boat is only 4 seasons old so it's not a question of age but rather if there's something better out there like a signal booster.
Also what is the trick with the in from the antenna going into the out of the booster??? I think Greg was saying something about that
Thanks. Mark.
Thanks. Mark.
Greg, I am on Lake Ontario close to Toronto. I get US channels on my TV. So it's not a matter of weak signal. They are there, but every 2 mins it drops for 1 or 2 seconds, which drives the kids crazy. You are correct, it's either on or off, it does not get fuzzy.
I have a 10" shakespear dish that came with the boat. I got the boat new in May 2012 (not even 4 years ago).
Here is a picture of my splitter to the top right (a bit cutoff) and the amplifier. I can see what you are saying about the splitter bringing 2 signals in reverse to combine to one for the amp. The amp is an AC/DC amp, but set to DC. I don't think they wired the 110V to it, just the 12V. I want to keep it working on 12V as the kids sometimes use the TV on the water, and I don't have a genset.
So the easiest thing to do is to take that splitter out (I don't use the dockside cable) and connect Antenna to common amp feed via an F-81 splice. Then go after the connectors, looks like 6 need to be changed in total including the ones at the F-81 splice. You mention compression connectors, do you need a tool to install these??
and what about the compression fitting that Mark ask about.
For the compression fittings, you do need a special tool. The last time I was in Lowes, they had a Snap N Seal compression tool and compression fittings for RG-59 and RG-6 connectors. The splitter needs to be a high quality 5-1GHZ with 120dB of isolation. Antronix and Regal are two really good brands. The Antronix one is available on Amazon in different flavors to suit your needs. http://www.amazon.com/Splitter-Broadband-output-capable-5-1002MHZ/dp/B008R3LOM0/ref=pd_bxgy_23_2?ie=UTF8&refRID=0S60F9WMJKPV7SP1PA8E
Cableguy Greg if you see this I had 3 wires connected on one side and 2 on the other side of my splitter. One was definitely the cable from the amplifier. One was going to my TV. The other much be going to a point I can add a 2nd TV in the mid berth. That's 3. I figure the other 2 are from the Shore Choice cable TV input.
Funny thing is on the one side it seemed it was a shore choice input with the two TV outs and the other side was the signal amp input as well as another shore choice (I have one on port and athe the stern). Do those splitters work bidirectionally?
