Do Rinker boats have factory installed galvanic isolators?
Does anyone know if Rinker installed isolators in the shore power circuits? If not can anyone recommend an isolator system that they have installed and are happy with? I have a 2007 350 EC and have had some corrosion issues latley after moving from fresh water to brakish. I generally leave the boat unplugged but would like to be able to have it connected to power and not worry about severe electrolysis issues. Any help on this would be appreciated.
http://www.deimarine.com/
You need to leave your boat plugged in if it sits in the water, otherwise your Mercathode will drain the batteries and leave you with zero protection.
You might check your trip tabs too, I had one crack and I suspect it caused my corrosion issues a few years ago.
