How can I get my Vinyl windshield clear.
I notice that my vinyl tent windshield was starting to cloud over. It has always been exposed to direct sunlight. I bought a product from the marina and applied it, and it got worst, and now I can’t even see out of it. Everything I try does not work. What do you guys used to clean your vinyl?
I think I have lost my windshield....everything I have tried is only making it more cloudy....some one told me to use pledge. I don't understand why only the one window....all the others are clear as can be. The canvas is 4 years old.
I am also going to try the toothpaste in a corner of the window.
The worst thing you can use is something that accelerates oxidation, such that removes oils.. when you're done with the toothpaste or the rubbing compound, rub in some mineral oil or light gun oil.. I rec the gun oil, as it can be bought in aerosol can.
I've tried a few products that came highly recommended but nothing has really worked on my slightly cloudy rear panel, but hey, it's 9y/o too. The compounding thing has me interested but from what I've read it's more of a polymer breakdown from age and maybe a little neglect.....which I can relate to.
Maybe somebody will break out the buffer and some light compound on an older retired panel to see if it'll massage it back to it's youth like those car headlights Drew mentioned. Mike
Port patrol in Bahrain used the gun oil every day.. we tried it in the desert on some equipment, but it was a sand magnet... We used (standing by for laughs) mop and glow on those.. it dried well as opposed to sticky.. highly rec it on a clean shield.
I have just gone through this. I had a small 10" x 3" section where water/condensation sits and it went yellow/dull. First of all to set expecations correct, it will never be 100% again. But it can be improved.
I used too much 210 and made things worse.
I bought some car headlamp cleaner and rubbed it in good to get most of the surface guck off. Then I added it a few more times, but this time a very quick and ver light pressure buff. The very quick light buff did the major difference and took it from very opque to clear. After this I sprayed 210 and gave it a quick buff. It isn't perfect but it looks a whole lot better.
Pledge is great for keeping clear glass looking clear. As a restorer? Dont know.
I use this stuff an it works great.
http://www.meguiars.com/en/automotive/products/g12310-plastx-clear-plastic-cleaner-polish/
copy and paste if link doesn't work
