For Rinker: Advice on How To Remove Seat on 2002 342
I'm looking for some tips on how best to remove the helm seat. I originally thought it would be as simple as removing the screws/bolts holding it in place, but getting to those is another story.
Thanks
Thanks
Removing the cushions themselves is pretty easy, just unbolt and pull off. Back cushions are held with velcro. I had to remove the whole assembly because I had some screws loosen up that I couldn't get to. In order to do that, look underneath the seat, there is a storage compartment. On the Stbd & Port inside of that compartment there are access doors that you need to remove. Once those doors are removed, you have access to the rail nuts. Two nuts on each side and the whole assembly lifts off.
Hope this helps someone.
I've also removed the sub-woofer and trash can....heck I've even removed the ice maker to get in there!!!
