Groundhog Day
Stodge
Member Posts: 2,738 ✭✭✭✭
From the WashingtonPost:
Punxsutawney Phil, the world’s most famous furry forecaster, failed to see his shadow on Tuesday morning, meaning spring is right around the corner, or so the folklore says.
The groundhog’s prediction came around 7:25 a.m. in Punxsutawney, Pa., with fair skies and temperatures in the mid-20s.
If this winter’s days truly are numbered, it will be remembered for both its mildness and brevity. Since December began, most of the Lower 48 has experienced above normal temperatures, the Blizzard of 2016 on Jan. 22-24, also known as Snowzilla, notwithstanding.
http://www.lre.usace.army.mil/Missions/GreatLakesInformation/GreatLakesWaterLevels/WaterLevelForecast/MonthlyBulletinofGreatLakesWaterLevels.aspx
@Stodge, thanks for the info - fingers crossed! I have to bring our boat down the Rideau Canal System through 15 locks to the St. Lawrence River.
Parks Canada guarantees 5 feet of draft. Of course, there has to be enough water to do that!
My 2014 EC 360 draws 47" draft - not much room for error - or low water!
Yes @DI. I have measured it from the waterline markings to the skeg and then in the water using my scuba gear. I was really taken aback and not too happy. A friend's 350 with 6.2s sits way higher.
Remember your boat is a LOT wider and longer than mine and therefore has dramatically different displacement data and front to rear pivot points.
Straight laws of physics at play here. My engines and drives are heavier than yours and I also have 5 AGM batteries.
I wish it weren't so but it is.
Yes, @DI my waterline is a LOT lower than 350/360s with 350 Mags or 377 Mags. Also, a lot of the guys "only" have 4 batteries (2 starter + 2 house) and many also have series 24 or 27. I have 5 AGMs that are series 31.
The brochure said "drive down, 36"....too funny.....maybe with an empty boat on the assembly line! LOL They probably used their "dry" weight of 15,550 pounds!!!!!
When my gel coat/bottom coat guy did my barrier and bottom coats he (thank God) set the line at the back (stern) 3" higher than I thought would be necessary. When I am fully loaded the waterline is right at the bottom coat line.....that's what got me measuring and holy cr*p I nearly had a heart attack - 47" .....Geez!
Agreed, that would be way too hard-on the engines and my wallet. But I have run it at 40+ for awhile when I thought we might be late for a dockside party!
85% of the time my boat lives at 3400 RPM, the rest at 1000RPM -idle through slow zones or slow cruising with the Admiral's friends on board.
Maybe because your 270 has one motor its sits in the middle and lower but my advertised draft on my boat is 35 inches. I will measure tomorrow to bottom of props.
By the way, on the maiden voyage of the toon it was amazing. We saw a lot of dolphins and we saw where the river water meets the clear ocean water of the gulf. Looked wierd
However a lot of people in skinny water still hit bottom because they don't take waves and momentum into account. One friend was on a boat and went over a hard rock shole. Waves moved all water out every 20 seconds or so and they were banging bottom hard!
