What type of anodes should I being using.
Bayrunner
Member Posts: 177 ✭✭✭
I cruise in the Chesapeake Bay and want to know if using the regular zinc anodes would be just fine for that type of salt base water.
Bayrunner -- FV312 - Simple Pleasure
http://www.chesapeakebay.net/maps/map/chesapeake_bay_mean_surface_salinity_spring_1985_2006
The parts in red (upper Potomac, northern tip of the Bay) are fresh, so most boaters there use magnesium. The blue parts, right near the ocean, are salt. The rest of the Bay is brackish to varying degrees, so most boaters use aluminum.
If you use magnesium anodes in brackish water, they won't last the entire season. With zinc in brackish water, they won't provide enough protection, so you increase the risk of corrosion problems.
