Fiesta Vee 310 12v blender
Bayrunner
Member Posts: 177 ✭✭✭
1. Has anyone had any issue with the blender performance. Making frozen drinks.
2. Also, the horn works on and off, you can hear it engaging but no sound. Is it fixable or needs to be replaced.
3. The starboard battery gauge does not work but the portside does. Do you think it may be a contact issue or needs to be replaced.
Bayrunner -- FV312 - Simple Pleasure
Hey Bay! Let's see...
first one, well, there are lots of opinions on that. I've never had the best of luck with the 12V blender. It ends up giving chopped ice. I've always had a small inverter and used a magic bullet (unless it's a big bash, then I run the genny for the vita mix!). I actually fit both the inverter and blender in the hole that the blender was in.
Horn, well, I believe it's the same as what was on my '02 310. The small little squeaker. I don't believe there is much to fix there, but I may be wrong. I know the subject has come up here a bunch. If it's the longer horn mounted up towards the windshield, you can tear them apart and clean the contacts.
Battery gauge, I'd check the wiring at the gauge first to make sure is has correct voltage. You could always switch with portside to double check (either wires or gauge).
So, Seneca Creek? Not sure I've heard of that. Looks like its waaayyyy up the Potomac?
06 Rinker 270
06 Rinker 270
but shrink wrap was $525 and I could have pulled it and stored it on land for the winter for about $1200 at some local marinas. mine didn't do land storage this winter as they were doing to have construction taking place in the yard.
