Navigation Lights Not Working
The red/green lights on the bow do not work on my 2011 260 EC.
The white light on the radar arch works in both positions on the rocker switch.
I cannot locate a fuse diagram for the fuses located under the steering wheel on the helm.
Can someone tell me where I might find that info?
Is it a single red/green unit at the tip of the bow? If so, I'd check the bulb (ie. loose, corroded socket, bad bulb, etc.). There should be a breaker for the nav lights but I believe the anchor light is on the same one so that's probably not it. If you have a voltmeter, check for voltage at the nav light.
Mark
2019 MTX20 Extreme
Hi Mark! there are two lights, one on each side of the windlass.
Not much of a night navigator so I had not noticed when they stopped working.
the anchor light is lit both sides of the rocker switch. Could be the switch I suppose.
Thanks for your reply!!!!!
2019 MTX20 Extreme
thanks Mark, will have a go at it in the morning!!
All set now, nav lights are shining!
Port nav light bulb was blown.
Starboard was a harness connection issue.
thanks everyone!
