Lenco trim control box issue
When i bought my 270 last year it had a non functioning starboard side trim actuator. The compression nut was cracked andI'm guessing thats how the electric motor got so corroded and failed. I replaced the actuator, spliced the wire just ahead of the bulkhead in the harness and all seemed well. For some reason theres a problem coming from the black control box. Switch goes on and off every time i jostled the box. Loose wire? I bent and pulled every wire to get a reaction and nothing. If i tap on the box it will come back on. Question: there are four screws on the box, is there anything inside other than what i assume is a circuit board that can be serviced? A relay or something? Whatever is in that box is the issue. Thoughts...
DIY, and yes on Vice versa
I can't figure out why the brain box needs to have proper orientation but maybe there is a leveling circuit or something along those lines. Good luck!
http://www.lencomarine.com/index.php/products/lenco-switch-kits/led-indicator-switch-kit-single
Worked the tabs up and down a few times and that's when the port side actuator screwed all the way out dumping water out of the cylinder as it dropped, lol. Better now than in the water I guess.
