Control From Home
So, I own an AV company and we also install security systems. I am considering installing a security panel along with various sensors to monitor battery voltage, water in any of the bilge's, intrusion and temperature. should be pretty easy and can monitor any of it on my smart phone via gsm communication. What I would really like to do is be able to control my air conditioning. Anyone know of any means to control the passport iq systems? I would think there would be some way to trigger with a dry contact closure. Monitoring the temperature and having the ability to turn on the heat should the temperature drop would be very convenient. Also, cool the cabin down during the summer on the way to the boat. Oh yea......
Sounds like a fun project. Details please!
thanks for the suggestion. I will give it a shot.
i also would like to be able to set a low temp point when in heat mode below 65 for cold weather, just to keep it warm enough to not freeze. I ordered a remote temp sensor.
That would be fine. Just think lowering the temp in the winter to maybe 50 would be a good idea. System would run less.
BTW if you have a camera that can see the HVAC control panel, you can monitor temperature (while the HVAC is on, that is).
06 Rinker 270
i plan to do it soon. If it all works out as planned and I don't know why it wouldn't, I could send a pre built kit with sensors already programmed for a DIY install to anyone who wanted. Pretty easy with wireless devices. It will also send notifications related to low battery on wireless sensors. Cell service is necessary fo all functionality. When out of range, system still works, just no communication to central station. Another feature that might be interesting to some would be geo fencing.
same as most residential and commercial security systems now.
Does your gsm provide a wifi connection? If so, you could consider a Nest home thermostat that is cell phone accessible.
If not, you could put your HVAC on a contactor/relay that is remotely controlled by your security interface. I assume you've got on output relay you could run it through. As long as the HVAC will go into it's last mode when powered up without any input, that would be easy...
I work in refrigeration, heavily involved with electronic controls. Coincidentally, I'm sitting in VA, connected to a site in TX monitoring and adjusting the refrigeration system. And... I have a co-worker that was the customer service manager at Dometic. I'll talk to him to help me understand what you guys have.
It's funny, a small world sometimes... My nephew is getting married at Devil's Den in a couple months. I have family in Jasper/Harrison.
So, with all this back and forth, what's your HVAC plan?
Named her "FAMILY THERAPY"
