What went wrong with my oil change?
rasburyrasbury Member Posts: 8,705 ✭✭✭✭✭
I changed my oil for the first time using for lack of better description , the oil drain tube vs. sucking it through the dip stick tube method, with me? Went pretty well, I suppose. This is only my 2nd oil change. I did not recall that when I pulled the oil filter off having such a mess last time. I did have a plastic bag and tossed it in but it was a little mess to clean. I used the draw tube for a few although I don't know I had a good connection to it as it looks like it should have a fancy connection to a fancy pump- mine is a harbor freight on a drill. The tube on it jammed in there and seemed to work. I switched to the tube on the dip stick to see if it would work better, the other way did so went back to it. I ran the motor to heat it up but let it set for some time. It's hot in FL so I wanted it to cool off a bit in the engine compartment. That was a jab by the way. Pulled that filter off and look like I stuck a pig, thought it would drain down better? Should you knock a hole in it to relieve pressure and then let it drain down a bit?
Best Answers
