best size and brand for 2000 242 Fiesta vee
Clinton
                    Member Posts: 44 ✭✭
                    I have a 2000 242 Fiesta vee and need to know what size is going to be enough without being too large and at a good price.
If you don't try to run any of those at the same time you can use a smaller generator. You will need to calculate the initial surge of your AC. There are plenty of small portable generators that should be great for you. Hopefully @frenchship will add comments as he has a lot of experience with this issue and did a neat custom install. I think a couple of the other guys did too!
http://www.homedepot.com/p/Ryobi-2-200-Watt-Green-Gasoline-Powered-Digital-Inverter-Generator-RYI2200/203617901
