Grey water elimination 2001 Fiesta Vee 242
Has anyone converted their grey water equipped boat to overboard discharge? I am looking to eliminate my grey water holding system as it has been nothing but problematic (not required on the body of water that I use the boat on). I would like to re route the galley sink, bathroom sink, and shower drain (if possible, not sure if the shower drain is below the water line). Has anyone attempted this? currently all drains run into the shower sump which I have changed twice. No matter what I try I constantly have a small amount of water under the galley stairwell, not enough to activate the bilge float switch. Just an annoying amount that you need to try and soak up with rags from time to time.
1. Can I eliminate the shower sump all together? or is the shower drain below the water line?
2. where do I access the port drains? I do not feel a fitting for a hose to slide onto behind the galley sink as far as I can reach. Do i need to pull the fridge to access it?
3. Where can you access the shower sink porthole?
4. I have all of the port drains, they are siliconed currently on the outside of the boat. Are there fittings present on the inside of the boat to slide the drain hoses on clamp on?
any help is appreciated. Just trying to get an idea on the job I have ahead of me before going ahead and tearing everything apart.
thanks
thanks
2001 Fiesta Vee 242. 350 MPI. B3.
1: No they all have that as far as I know. Only Shower drains to it on mine....all other sinks (3 on mine) go right overboard.
4:I would think if hull fittings are there, then they would still be there on inside, as that the way they are built, One piece with a nut.
@MXZ0588, it sure would be a bonus to have all of your grey water go overboard as it would surely save a lot of space. Speaking of space where does it go now - into the solids waste holding tank or is there a designated grey water tank too? If it goes into the same waste tank as solids (the head) I would have it going overboard ASAP!
I took some pictures for reference in case someone else needs to perform something similar.
This is the galley sink with the refrigerator removed for access. Easy with just removing 4 screws on the front of the fridge.
Below is the access for the bathroom sink and shower sump discharge:
shower sump routing:
Grey water tank that is no longer being used:
Thanks for the help guys.
