Best way to plug a 1.25" hole on inside of hardtop?
LaReaLaRea Member, Moderator Posts: 7,961 mod
Can anybody suggest a good, clean way to plug a 1.25" hole drilled into the inside surface of a fiberglass hardtop?  It's a cosmetic plug (not water-tight) that needs to be removable.
The surface might be slightly curved.
The reason is that I need to install additional safety rails on the outside of my hardtop.  That means I need to drill some holes:  1/4" bolt holes through the outer layer, and 1.25" through the inner layer so I can insert a backing washer and nut.
Or, if somebody has a better idea for how to install grab rails, I'd love to hear it.
