Battery charging
                    I have 4 AGM group 31 batteries for my 2006 342. The battery isolator has provisions to charge 3 batteries. It is wired to charge each battery to my engines which means the third is used to charge both house batteries in series. Question is the Rinker charger designed to charge the 2 batteries in series?
Yes you can run two house batteries from the "house" one output of your Intellipower cahrger. As Al said be sure to switch to AGM selection on your charger. As well, you need to make sure your HOUSE batteries are connected in the following manner. Run the +ve (Red) cable from the Intellipower Charger to the +ve terminal of the FIRST house battery. Then run a cable from that terminal to the +ve terminal of the SECOND house battery. Next, run the -ve (Black) cable from the Intellipower Charger to the -ve terminal of the SECOND house battery. Then run a cable from that terminal back to the -ve terminal of the FIRST house battery. This will not only give you a 12 volt parallel system but also give you better power supply, far better "evenness" of charging and longer battery life. If you have any questions google Progressive Dynamics as they have a great website. You can also contact them at 1-269-781-4241. Their website has info on battery types and wiring configurations although the method I just told you will work best for your application. Good Luck! MT P.S. - great battery choice AGMs are THE way to go!
How is the charger "Switched" to AGM type batteries? I looked everywere this weekend and cannot find anything to single out AGM batteries on the Intele Power PD2040. The gentlemen from DEKA stated that the battery charging requirements are the same for agm and only different on the GEL battery. Any thoughts?
Mike
P.S. It is a pretty accepted rule that all batteries should be of the same chemistry. However, I believe that I was told that you "could" have two flooded cell starting batteries and two AGM house batteries if they were on separetye charging circuits. The reason i was given was that their charging profiles are so similar that neither would be harmed while charging - and - since they were isolated for discharging there would be no harm. However I would DEFINATELY check this with Penn Deka before I did it. In my case i had to buy four new batteries anyway so I just made them all series 32 Penn-Deka AGMs. MT.
