Refinishing bravo 3 HELP!!
Trashman
Member Posts: 432 ✭✭✭
The po of my 270 kept it in fresh/brackish water for the last 2 yrs. before that in stone harbor nj( salt), he kept the salt water zinks on. Told me corrosion had been at its worst the last 2 yrs. I still haven't checked the Mercathode below the trim manifold but plan to just replace. There were a few if the little ground cables busted.
I'm keeping it in the Delaware river , brackish/ fresh, I guess.
• I went with new magnesium anodes, good???
• wire wheeled the bad corrosion and will finish off with some sandpaper to smooth things out there will be quite a bit of spots with bare aluminum,I'm trying to keep as much factory paint on as possible. What do I use to prep the drive for paint?
•What do I use to primer the bare aluminum ?
•There are a few heavy dimples, can I fill these with something before priming or it's no real concern?
•I saw a video where a fella used JB Weld to fill and smooth out his skeg, has anyone done this ?
So many videos, can't decide just what is PROVEN to be the best way to refinish my b3.
Heres a pic of what I've started with and what I've done so far.
good luck!
http://www.boatered.com/forum/topic.asp?TOPIC_ID=97217
Basically sand down corrosion to bare metal like you have done , I used 80 grit wet dry from 3m. Rough up existing paint(various grits depending upon if its drive paint or the Merc factory paint). Clean drive with tack rag or some sort of cleaner, others have used vinegar, paint thinner,etc. I took off props to clean them and grease the shaft, also makes it easier to paint. Tape off the electrode underneath the gimbal housing, hull, wire mesh trim hoses, prop shaft, trim cylinder shafts. I did 2 coats of Trilux Primocon primer. Some say do white coat then grey coat so you can see where you painted. Some use zinc chromate, I didnt, not sure if its necessary or not. Most didnt say to use it. Then two coats of finish paint. I am going to use Pettit prop paint, see how it holds. WAY cheaper than prop speed.
If I missed any steps anyone please fill in, I am not an expert by any means.
06 Rinker 270
@Alswagg, I actually have a good connection for getting powdercoating done but my feelings are that I already have significant corrosion and feel PC may not be in my best interest. Also, id have to take it all apart. That would require more special tools and way more knowledge than I possess.
In no rush, the drive is on the stand and I am chipping away at it a little each day. Let the advise keep rolling in. Lol.
Next wa a few coats of zinc chromate, green . Then several Coates 15 mins apart, of mercruiser phantom black. 2 light Coates on the mating surface where outdrive bolts together. Still contemplating another coat after it's been sitting a day or two.
...Currently working on the drive.
Best drive prep and paint job I have seen in 50 years of this type of effort! IMO.....TEXTBOOK!
These had to be media blasted.
FAIRLY EASY!!!
I used a small blaster I borrowed. Looks like it would hold 10 gallon.
Started out using the black 70grit media that was in the blaster. Was ok but left a finish similar to 900 grit sandpaper.
I bought 80 grit glass beads better finish for sure, like 1500 grit sand paper. $44 at harbor freight for 50lb. Reused about half I recovered off the tarp after sifting.
Had to do at a friends house because the blaster needs a good sized compressor. Makes a mess!
I put the drive on a wheel barrow on top of a tarp. Not ideal but was limited to what was available.
wore a tyvek with hood, goggles, good leather gloves. The media gets everywhere!!!! In hindsight I would suggest buying the cheap little hood for your head and ear muffs.
I worked on the drive last nite, here's a few pics...
2- Bearing carriers with a light coat of epoxy to seal. I cleaned out all of the corrosion first. Corrosion was mostly bearing carriers and a little on the drive near the prop.
1- starting point. Someone painted them with Trilux years ago and neglected anodes.
4- final, new anodes
3- done but props not on yet. Painted with fresh Trilux 33. This was before I sanded and repainted the transom too.
Liberty, ....I noticed that it looks like you have the bottom paint on the transom communicating with your outer gimbal. I believe this is a no no from a corrosion standpoint.
