Is there a differance in the hull of a 270, 280, 290
randy56randy56 Member Posts: 4,085 ✭✭✭✭✭
All are 9ft wide, all weight with in 200 lbs of each other, if you compare the bottom part of the hull they look the same. Except the molded in swim platform on newer models, all are very close 30ft 4 in, +- So the first built was 270, then 280, and on to the 290. ???
    Thank you, differant molds, improving as they went along I supose. I have so many questions. does Rinker allow tours ? I'll be in Indy next week and its only another 4 hours.
    Will do!
