Identifying a Outdrive/Sterndrive, Bellow Replacement
 Fishermann24
                    Member Posts: 2 ✭
Fishermann24
                    Member Posts: 2 ✭
            I have a 1988 Rinker Fiesta Vee, with a 260HP Mercruiser. I am going to try to replace all bellows, gimbal bearing, gaskets, throttle cable etc. However, I am trying to confirm that the outdrive is a Alfa One. When ordering my "Bellow Kit" I saw Alfa One with difference generations. I have attached pictures of my outdrive for help confirming this. I am not able to see any serial numbers/labels due to the previous owner painting over everything.
Also if anyone has any tips/advice for bellows/throttle cable replacement I would greatly appreciate it. I understand that it can be a very time consuming/frustrating job but I am willing to do it rather than paying $100 per hour to have it done locally.
Thanks in advance,
Are you sure it's a generation 1? It looks the same as mine which is a gen 2. I think the gen 1 has smaller hydraulic rams. I'm not 100% though.
