Electric receptacle
mskpharmd
Member Posts: 44 ✭✭
hey guys I have a 1999 330 and my receptacle down below appears to be a ground fault interrupter that has gone bad. I need to replace it, can I just go to Home Depot and use a regular residential replacement or do they make special marine ones?
thanks in advance....
mike
philly fanatic too...
mike
a) there is no special marine GFI.
b) The screw terminals on GFI's typically have a "plate" under which you insert the stripped wire and then tighten the screw. This method is fine for both stranded or solid wire. Do not wrap the wire around the screw, use the plate described above, it makes a better connection.
c) LaRea is correct, marine wire is stranded tinned copper.
d) If your boat has the crimp-on terminals, if the terminal is in good condition and is well crimped ( I've seen some really poor crimped connections-- you could pull the wire out), the terminal can go under the plate or under the screw- whichever works.
e) Buy a name-brand GFI, the cheap ones have a high failure rate. This applies to your home as well.
Andy
http://m.ebay.com/itm/RINKER-MOLEX-BLACK-20-AMP-BOAT-ELECTRICAL-OUTLET-W-COVER-PLATE-/191529701702?nav=SEARCH
What are the receptacles hanging from the bottom in that ebay photo?
06 Rinker 270
06 Rinker 270
Yes, I went to an electrical store to make sure I got the black color for the cabin and a white for the cockpit and had a bit more quality choice but HD would be fine.
06 Rinker 270
Sorry @mskpharmd hope I am not hijacking your thread too much. Let us know if you solved your problem.
06 Rinker 270
I have put them in key locations in my house as well so I don't tie up plugs with charging transformers. Amazon sells them in black. They are made by Cooper.
06 Rinker 270
06 Rinker 270
06 Rinker 270
gslpro good advice about buying multiple. And yes I will be disconnecting shore power and also have an AC tester just to double check.
06 Rinker 270
I tried just unscrewing the GFI plug and twisting it out of the hole but there doesn't seem enough space for that...
