Guess it was time to change the hoses
I looked over the hoses for the head and the A/C, and thought after 10 yrs they were getting a little hard/brittle, so thought I would swap them out. Good thing......after getting them out, they were getting quite cracked! Better not to mess around with stuff below water level I guess.......and if anyone wonders, A/C unit it a BEAR to get out to change hoses. A/C ones not cracked but hard as a rock.
A
Both have severe bends in them, bad set up.
@BMXZ and @BD - Agreed and speaking of crazy bends. The exhaust water hose from my generator to the muffler/water evacuator used to be bent with such force that I thought it would crack the fitting on the generator and/or the evacuation unit.
I consulted Rinker and they agreed. God bless them they sent me a 90 degree elbow that I had the technicians install.
I am a firm believer not to underestimate the stress placed on hose and the trouble that can cause.
Also a firm believer in double clamping whenever possible.
Picture attached.
BTW you may notice the hard plastic pvc protective cover I put on the underside of the upper hose. It was resting on a battery terminal....yeah!
Yes i'm going to try and get some bronze 90s , as I changing seacocks at same time
Double clamping.... what a simple and cheap insurance policy, I had never thought of it but will be adding a few clamps to mine once the shrink wrap comes off.
Great tip!
Too much stuff to look after........I guess.
Yep always something
