Anodes- What do i need.
This is my first boat that stays in the water and i know i need to grab some anodes, hoping someone can tell me what though!   2003 342 with Bravo 3's.  I know the p.o told me as does the maintenance excel sheet i received with the boat that when he replaced the lower legs of the B3's he got the newer version with extra anodes.  So since i don't yet have access to the boat but i am attempting to show up with all items needed can someone tell me what i need.
    First, I assume your boating will be fresh water boating - that would be Magnesium anodes. If you boat in brackish water (salt/fresh mix) you would want Aluminum anodes and ocean salt water would ne Zinc anodes. I have the kit # for Mercruiser parts somewhere. I'll look it up if someone doesn't post it first. You can also but the kits at West Marine, Defender Marine and a lot of marine supply stores.
    Amazon has some good prices also.
    Boatzincs.com is where I buy my anodes.  For bravo 3s they recommend the aluminum alloy in salt water. The older alphas called for zinc. Also replace your water heater and genny anodes.
    IMO if you are using Aluminum anodes in salt water you had better check them frequently,  have a well functioning cathode system, have a galvanic isolator and not be in a marina that has a lot of stray electrical currents. I'd be very careful with Aluminum anodes in salt water!
    +1 on Boatzincs.com.  Being you're in Cleveland I'm guessing Lake Erie so magnesium anodes should be right.
    Sorry,  Yes I am in Cleveland on Lake Erie.  Is there a kit number, since they replaced the lower legs with newer ones that have more anodes Im not sure what kit to get.
  • Cableguy GregCableguy Greg Member Posts: 5,053 ✭✭✭✭✭
    I use boatzincs.com as well. They have good prices for their stuff. Since you are in Fresh water, you are going to want Magnesium and if it is a newer style lower unit, order the Bravo 3, 2004 and newer kit. You will also need trim tab anodes. I get the 3 inch ones, but some of the boats had the hole drilled too close to the actuator, so you might need a smaller one.
    http://www.boatzincs.com/bravo3-mag-kit.html
    @Wildboating....then back to my original reply to you, you should be using Magnesium anodes. How new are the lower "legs" AND do your props have nthe bolt holes to accept the prop anodes?
    Mercruiser Anode Kit for 2014 and newer Blll drives with prop anode: 888760Q04MM  I paid about $111 for each kit *****MM stands for magnesium
    From West Marine:
    Bravo lll 2004 to present: Magnesium Anode Kit - 11426764 $119 each
    It says this kit contains the extra pieces required for newer B llls
  • BayrunnerBayrunner Member Posts: 177 ✭✭✭
    edited March 2016
    Since MT answer your question I thought I would offer up a web site for you to look at for winterizing and boat maintenance on a Rinker FV312. Hope they offer some good information to you.   www.youtube.com/user/liboatersclub
    Bayrunner -- FV312 - Simple Pleasure
    Thank you everyone!!  This was a big help.  I will crack open these boxes that just arrived of Hill marine 4 x 4's and see if they have holes Michael T!
