2003 342 Port Fuel Tank Leak
DaveG
Member Posts: 23 ✭✭
I have a leaking port fuel tank on my 2003 342 Rinker. Any suggestions on the best way to remove fuel tank to get this repaired? Has anyone else experienced this problem with this model?
Very disappointed with Rinker Boats. No help from factory. Seems to me fuel tank should last longer then this! Boat I sold when buying this Rinker was over 20 years, never had a issue like this.
This Rinker has been lift kept it whole life, never kept in water unless being used. Only 375 hours, Shame on you Rinker!
The fuel tanks are next to impossible to access. I've heard of people getting to water and waste tanks by removing the mid-berth. Not sure if that will get you to the fuel tanks too, but that should be where they're located. The only other access that comes to mind would be to pull the motors, then pull the firewall.
I hope you're able to find a solution. Having the same boat puts me in danger of the same issue.
Yes, Rinker doesn't make that tank. Also the leak could easily be a function of not having proper grounding, or acidic solutions coming in contact with the outside of the tank, so it's difficult to ask Rinker to take responsibility.
It sucks though, I get you.
You aren't the first person to have to deal with a leaking fuel tank (not just Rinker). Check on this forum, do a search. There are a few that have gone through this and know what to do.
1) Wrong throttle cables
2) Bad transom glass finishing causing transom bracket to break.
3) Poor over all wiring.
Shall I continue?
Just thinking out loud and venting.
Fuel tank failures are rare, but the ones that do fail tend to gather a lot of attention because the repair costs are so high. I hate to say it, but your boat will need major surgery. People who build express cruisers, in general, do not bother making it easy to remove the fuel tanks (because the failure rate is so low).
I've never heard of it happening on a 342, but I hope you can find someone who has done it. Like @Stodge said, I am guessing you'll have to pull the engines and remove the firewall.
I've never taken the tanks out but removal of what I stated above gives you great access to the tanks. Couple of hrs the first time to get to the tanks.
Has usual you give excellent tips. Would that same process apply to the 300 express 2007.
Thanks
Paul
Added dye to fuel tank and used blue light and did not see any leaks at fuel line or sending unit. Saw dye between side of tank and and hull. Was able to remove cover over sending unit under seat and look down on tank.
Thanks for the info.
If been through this before Dave and no it wasn't fun but I had a stronger boat when it was done. But if I had to do it all over again I would take my time and do my homework. I relied on the "Professional" option of my Marina owner at the time and got burned bad Find the best technician you can for the job who has the proper training and didn't learn his mechanic skills from the local shop. I would also do as much work myself to save money. Sounds like taking the aft cabin apart isn't too crazy.
I have relied on the advice from the people on his forum and always came out on top. Good luck Dave.
06 Rinker 270
Thanks Al for that great info.
Going to tackle this project soon. Will let you all know the outcome.
Just trying to do all my homework before I get started so there are no surprises.
Thanks for any help you can give me
Dave G
