Shore water connection connected to nothing
redlightning
Member Posts: 284 ✭✭✭
so continuing to work on small fixes and familiarizing myself with all of the nooks an crannies of the boat.
I had planned to connect water to the boat from the dock this weekend. I understood that this connection bypasses the fresh water holding tank and if I understand correctly the pump is not needed.
I was in the motor compartment looking around and found this. The top connection is the back side of the connector on the swim platform for the "shore water".
Really glad I didn't connect it and just turn it on.
Why would this be in place and not be connected to anything? What or where should it be connected?
yep
I could have done that. where would that connect? Anyone?
http://www.ebay.com/itm/like/110870715568?lpid=82&chn=ps
http://mobilehomepartsstore.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=160401
thanks a lot!
I will look it over and see it a t is in place.
if not I will try to figure out where that should be installed. would I be correct that the pump does not need to operate when on city water? it should feed into the system so as to feed the cold water but also the hot water tank?
Anyway.......if anyone with a 2008 or close 330 happens to be on your boat in the near future, would you take a pic of where the factory made the connection from the shore water input into the fresh water system, I would be forever in your debt.
However anywherr between the pump and the first cold water tee off to a user will work.
This is the item.
Tony
I am really glad I noticed that hose missing. I was ready to connect a hose ans turn it on.
I believe this is the part Tony is talking about, as you can see, I always carry a spare. LOL .....I find this the best unit as it has a lower pressure cut-off than many others (often at 55 or 65 psi) but still has more than enough pressure at 45 psi.
I have found the flair-it connections leaked when first new (better for Rinker to have under tightened them than to crack them - and as we always say on here, its the owners' responsibility to check the fittings regularly anyway) - so I tightened them VERY CAREFULLY by placing an old face cloth over them and using a plumber's wrench. End of leaks.
BTW if I'm away from the boat for more than an hour I remove the hose from the transom fitting - just because.
