Pulling the boat out for service
pulling the boat to get new trim sensors installed on my VP drives. Planning on having motor alignment checked, new gimble bearings and bellows replaced while drives are removed. Shop is going to do basic maint and checks on drives and oil, impellers and filters on the motors. Also going to have the generator serviced. Is there anything else I should have checked or serviced during this event? Thanks in advance for any feedback.
Fresh water pump impeller.
How is your gear lube? If it's being consumed have them check the prop seals.
How many hours on the engine?
Oil change, full tune up, carb rebuild, ANYTHING that it needed before you pulled it out.
For some reason doing stuff on concrete is way easier than doing it in a slip.
