Wiring diagram help
Attached is the wiring diagram for the swim light, if my 360 had that option. The switch and wiring is there and now I am trying to locate the blue/lt blue wire in the engine room, which is terminated somewhere that I haven't been able to find.
If I am reading this correctly it shows that the swim light switch already has a 5amp fuse inline, correct? I have 3 lights I am installing from coastal night lights and he recommends a 10amp fuse. I suppose I could just swap the 5amp out for a 10 amp, no? Or should I put an additional 10 amp fuse somewhere in the engine bay?
Also I can't seem to find a good boat wire diagram symbol key anywhere. Perhaps you guys could help this electrical novice out. The way I interpret this diagram is: batt switch powers the helm disty bus; helm disty bus powers a 5 amp fuse (or circuit breaker??) at the helm; orange/gry power runs from fuse through connector 9 and 10 and then directly to the toggle switch; it then changes to blue/lt blue and from 16 to 14 gauge wire; goes through connectors C11 and C21 in the helm area before making a long run back to the swim light; and then I will just ground the 3 lights to a grounding block in the engine room. Did I do alright with what these symbols mean?
I think that what they call the swim light is the actual light that is already installed on your boat right above the the rear platform below the transom locker. The wiring harness on my 300 show the same diagram.If Rinker had already installed an option for the lights you want to installed they would have used a larger breaker than 5amps and bigger wires As far has installing you new lights I think you would need to run new wires and proper fuses or circuit breaker and switch to your dash panel. Also make sure you run the proper gauge wires.
