Stuck piston ring
I have researched this online but I trust some members on this site and was hoping to get some feedback from them.
2004 6.2L Mercruiser Horizon FWC inboard 307Hr
I bought boat late last fall, port engine risers/manifolds had just been done but not starboard engine. The survey and compression check were good, boat achieved rpm at WOT. I ran the boat for 2 weeks (a couple hrs) no problems winterized and stored. This spring before launch I had marina do risers/manifolds on starboard engine, they found almost no compression on 2 cylinders due to valves (could see some corrosion) sent heads out had them redone.
Now those 2 cylinders have improved to low compression 100psi. Sounds like stuck piston rings and the boat has not been run yet to see if it frees up so this may be a bit premature. They are replacing water pump today then run and see if compression improves. If it does not is there anything I can have them do to help free up the 2 piston rings before pulling the engine for major work?
2004 Cruisers Yachts 320 W/6.2L I/B's
Boat Name- Anchor Management, Mayo MD
Best Answers
Optionsjhofmann Member Posts: 430 ✭✭✭Penetrating oil is used to free up a piston that won't move due to the rings being rusted to the cylinder wall (called summer seize in the snowmobiling world). I like 212rowboat's idea of honing the cylinder with the piston at it's lowest point to use friction to try and move the rings. If all else fails, you could try using oil as a last attempt before pulling the motor.
OptionsDream_Inn Member, Moderator Posts: 7,561 modCC, I'm assuming that Brian is working on this? I'll be real curious what they come up with, as I believe you have the right people working on this.
OptionsChesapeakeChiller Member Posts: 98 ✭✭Yes Brian is working on this and he may have suggestions before major work. I think I am just a bit nervous about this and trying to get to far ahead of it.
did you see the bores before the heads were planted? what kind of condition were the walls in?
but even said- run the engine to temperature.... after a few cycles of this it is likely to break free anyway...
......penetrating fluid doesnt work well.....and don't hone it.....very big risk of oil consumption doing that. That said if cyls look clean will.probably ly free up itself. ......can always use seafoam after. ......just pull plugs on bad clys and pour in through plug hole on preferably hot engine
BUTT with this engine being a fuely injected engine I would doubt you have a carbon build up.
I asked a builder about this, and he spoke the obvious after squinting at me for a good solid second... he asked "Heads off?" and went on to answer before receiving response- he said to drop the piston to BDC, and 'tap' it around the perimeter with the handle of a mallet and another mallet... BDC because the skirt has a mill or two less tolerance on a marine engine in the unusable bottom of the cylinder (which answered and age old question of mine, "what are the differences in a Marine block compared to a Auto block?).. the wrist will wiggle and free up more often than not stuck rings.. .
"heads on" was the next question and same thing (response not needed) saying "compressed air in cylinder on compression stroke starting at BDC and bumping starter all the way to BDC of power stroke, then fast turning it a few cycles stopping at BDC/compression stroke again- adding a touch of oil, like you're doing a leak down test at TDC"...
but he also said "run the *&%*& thing".... nothing will assist like heat and varying RPM's..
