Mod to keep the aft fill cushion from slipping
LaRea
Posts: 8,068 mod
I came up with a simple fix for a long-standing Rinker issue related to the cockpit aft fill cushion.
The cushion I'm talking about is the removable cushion for the port side of the transom bench seat. It has been standard equipment on larger Rinker cruisers for the past 15 years or so. The problem is that if you step on it when boarding the boat from the port side, it can slide out from under you. My wife loves the fill cushion, but after using it a few times, we realized that it's just too dangerous to use with guests on the boat.
This is a 2-part fix involving nothing more than marine lumber (Starboard) and six screws.
The fill cushion has two metal legs that rest on a ledge at the front of the transom bench seat. The first problem is that there's nothing to keep the cushion from sliding inboard when you step on it. What I did was cut two pieces of 3/4" x 3/4" x 3" marine lumber and screw them to the ledge next to where the legs rest. Simple, unobtrusive and effective.
The second half of the fix is to keep the fill cushion from rocking when you step on the inboard edge. I cut a 3/4" x 3/4" x 5" piece of marine lumber and screwed it to the underside of the fill cushion, right in front of the existing piece.
With these two simple mods, the cushion is stable and safe. I wish I had thought of this many years ago. Now that I know it works, I'll go back and seal the screw holes with marine sealant.
Awesome fix! That will be my next mod!
Very classy modification! When the Admiral was standing on our aft bench filler cushion (2014 EC 360) for the first time to zip some canvas I heard a crash. The filler cushion had shot out from under her and almost thrown her overboard. She could have been seriously injured. I bought two thick ribber stoppers about 1" high by 1" in diameter and screwed them into the lip of the back seat with ss washers and ss screws. That holds the cushion well too. Hmmmmmm, makes you wonder? MT
Yet another outstanding fix from a Fellow Rinker owner! Now I need to order up another piece of Starboard!
Good job
Thanks guys. If anybody else does it, let me know any suggestions or improvements.
Note - for the forward edge, the 5" piece on the underside of the cushion can't be wider than 3/4". Otherwise, it would hit the trim of the plastic storage compartment.
And yet another mod lol great idea thanks for sharing
That is great. I used to have problems on my 310 with the triangular piece.
06 Rinker 270
06 Rinker 270
Great fix!
Does anyone know how/where I might order just the one port side filler cushion?
I am thinking that just having the one will allow us to still utilize the pedestal table.
We have a 2004 FV 270
Thanks for any advice....
Phil and Bonnie
