Rinker 260 VHF marine radio
Hi,I need to re-program the VHF-marine radio with an ATIS-code.
Can anyone tell me where the marine-radio is located ? (is it located behind the white microphone ? do I need to take out the soundspeaker under the white microphone ?)
Thanks for information
Thx
Your VHF may not have AIS capability.
Many VHF units in North America now have automatic DSC but many models do NOT have AIS, so it would depend when and where it was purchased and what model you have. I would look your model up on the internet or contact the manufacturer if there is doubt.
For example you can purchase a Raymarine 260 VHF for $699.99 without AIS or for $999.99 with AIS.
ATIS means : Automatic Transmitter Identification System
@LD In Europe it may be called ATIS but here, In North America, it is called AIS which means Automatic Identification System.
In North America when a VHF with AIS is connected to a Radar or GPS/Chartplotter it sends out an identification signal.
It sounds to me like we are talking about the same type of system, just with different initials.
Again, your model and make numbers should tell you if your VHF has that capability.
The head unit that your handset is connected to should have that information for you.
@LD, you may wish to "google" standard horizon units. I did and there are a lot of models, some with AIS and some without.
It looks like your RAM+ handset is an older unit that is no longer in production, although replacements are available. As you probably know the R stands for remote control of the head unit.
BTW Standard Horizon refers to their identification system as AIS. It looks like your RAM+ is the hand held "handset", as I suspected, and is compatible with a number of different Standard Horizon head units of different capabilities and wattages.
From what I have read your Ram+ hand set should be compatible with an AIS equipped head unit if the head unit is AIS capable.
I recommend that you find out what head unit you have, then you will know if it has AIS.
If it has AIS but you are unable to program it, then I recommend that you look-up the contact information for Standard Horizon and call or e.mail them as I have found, over the years, for them to be very helpful.
