Trim and MPH Gauge not working
Hi Everyone!
I recently had my motor rebuilt after a several year hiatus and now works great!!
But my Trim and MPH gauges don't work. All the rest work fine.
First: I looked behind the panel of the Trim gauge and there seems to be a red wire strung along towards the trim pump (in the engine compartment) but doesn't connect to any of the many wired connections on the pump.
I tested each one to see of I get a proper usage response, but nothing.
Which connection nut on the trim pump does that red wire connect to?
Second: I think the MPH gauge is properly hooked up to the outboard correctly....but to make sure,
Where exactly does the MPH gauge hook up too?
Turns out my Oil Gauge isn't working either....Hmmm.
All Gauge Lights work.
Here are some pics of the gauge set...
The first pic is the Trim Gauge.
Thanks in advance guys!
Here is the Trim Pump connections...Anybody know where to connect the red power wire coming from the Trim Gauge?
Post edited by artistofdesign on
