Removing all the old striping/lettering.....
BellevilleMXZ
Member Posts: 732 ✭✭✭
Sucks.....that is all.....lol Guess it will look good with the new stuff though.
My old boat's stripes were so brittle I had to use a special eraser type wheel on and air grinder. It's a pleasure if you can just use a heat gun. Btw, I see you have a 2005, mine is an 04 and I do need to replace the top black stripe with the 1/4 gold leaf running through it. Where did you buy your new striping?
Yah I used the combo of the wheel and peeling depending on what I was taking off. Hardest part was the glue....THAT was a pain. Lighter fluid worked the best out of alcohol/wd-40/goo gone/adhesive remover.
I wanted newer style black/ 1/4 grey like on newer 270s......Rinker was no help, so I said screw it. Its gonna get black stripes in same width as stock and a dark gray/metallic 270. Just getting local place to make up and install
I also bought a set of the chrome rinker decals off ebay like on the newer ones. Ive never seen the black/gold listed anywhere.....good luck with rinker.
The eraser wheel takes up the adhesive as well. Where I could actually get it to peel I used acetone to take off the adhesive. It worked well. None the less the whole process was a major pain. I still have to do the upper stripe above the rub rail. Once that is off I'm not even going to replace it. I like the clean look of solid color with no pin stripes, just like my cars.
http://www.amazon.com/AES-Industries-51823-Eraser-Adapter/dp/B00488DDB8/ref=cm_cr_dp_asin_lnk
I bought a 50' roll of new blue and gold Rinker striping from Great Lakes Skipper.
www.greatlakesskipper.com
I'm waiting for cooler weather to finish the job
Andy
06 Rinker 270
I removed my boot strip last winter, hair dryer and a single edge razor blade made it pretty easy work. I am not going to replace it, looks better without it I think.
Planning on redoing the stripe around the bow this winter. Change it to black and add a grey 1/4" stripe to match the boat colors.
https://www.amazon.com/3M-03618-Adhesive-Remover-oz/dp/B000BQYA7W/ref=pd_sim_469_3?ie=UTF8&dpID=414Ca96Xl2L&dpSrc=sims&preST=_AC_UL160_SR160,160_&psc=1&refRID=3MFGW2DRTNNNE8KC7SQ3
Now I have a stripe of shiny gel coat that the whole boat had in 2006. I'm not sure I'll install the new stripe just yet, I kind of like the clean look without it. Tomorrow the port side stripe comes off and guys on the dock will stop asking why I have only one side striped.
Andy
06 Rinker 270
I also took advantage of having no graphics and compounded and polished the transom. Always been a pain to work around the graphics without destroying them and it always bothered we that I could see a dull finish around the lettering. Next weekend I will wax over the transom to protect everything.
06 Rinker 270
@LaRea yes I have a feeling I will be seeing those old letters for quite some time as they were on there for 10 years. I did the compound more so for easy buffing than for removing the line of the old letters. Although one round of compound did a great job. I can never seem to get that shine right up to a graphic, button or RINKER silver decal with a buffer. I try with my hand using compound and it just makes it foggy.
06 Rinker 270
