2007 Merc 350 Mag Cool Fuel System
Quick one to run by everyone...
Marina doing some spring work for me let me know that there was some type of bulletin on my motor based on the serial number. The bulletin indicated that my motor may have had a painted instead of powder coated component installed from the factory as part of the cool fuel system. Because it was painted and not powder coated, the paint is flaking off and can contaminate the fuel system and cause issues.
The bulletin (I read it myself) said they recommend that if peeling is observed the part should be replaced with an OEM powder coated one. Marina sent me a pic...paint definitely peeling/de-laminating.
I have no idea what this is, what risk it may be, or if I should spend another $500 bucks to get it fixed. Pic they sent is below...clearly the area is peeling paint....
Thoughts??
Eric
Thoughts??
Eric
.....double check this but I believe if the paint flecks make it past the two fuel filters of the cool fuel module and get into the fuel rails/injectors the $500 may look like a bargain....and I agree 100% with @belle-vita, mercury should pay. they are usually decent about these kinds of things and this cool fuel module issue has been well-known for a long time now. IMO
If it happened to me I would contact Mercury and ask them about accessing their goodwill customer support program - at least send me a new module gratis and I'd cover the installation or do it myself. It costs nothing to ask respectfully.
Better check your source on being the first one to bring that subject up.....
Paul
Eric
Ras you might be okay but I'd still be worried that more could come off and clog your fuel delivery system. I thought someone else manufactured these - could it have been Hardin Marine? They seem to pick-up where Mercury fails?
MT, hardin did the water pumps. I'm sure there is an off-brand, but is it worth messing with for fuel?
Ras, as far as the paint, it doesn't come off all at once. A very small flake, like the tip of a pencil, will cause your boat to not get on plane (believe me, I've been there). So who knows how long it would take for all the paint to go.
