Wet rear berth compartment in my 2002 342
Last year I noticed that the carpet in the rear berth compartment was damp, not soaked but damp. I notice the same right now as I am about to launch. This indicates to me that it must be rain water that somehow gets into this compartment in the middle of the boat. Strange I know. Anyone experience the same and did you figure it out? Anyone have any suggestions of where to look for the source of the leak?
2. Check your A/C and toilet strainers and the A/C pump
What is underneath this compartment? I assume a hollow area for water to run to the bilge pump behind the compartment.
There 'should' be drain holes in the stringers from the A/C pump area to that bilge...should be. If not, any water from that area will go in there.
Did you verify no leaks from the A/C pump while it was running? Run the shower AND aft bilge pump with water, check for leaks in the hoses, that flimsy hose can get pin hole leaks.
They make Flex Seal in different application types. Tube, brush on , spray on and tape. Check out the link.
https://www.flexsealproducts.com/shop/?gclid=Cj0KCQjwuYTYBRDsARIsAJnrUXASIZBDXbvEaLRv2aRrwLzbhAcc78jHSTtk_vnlxff1jtEY5G6arPsaAqS0EALw_wcB
On the 342, that “aft bunk” is really a mid-cabin bunk.
+++ on the anchor rode locker too.
https://youtu.be/LvKAkZA9wKA
1998 Regal 2100 LSR
