Stuck gear lube drain plug
chamberb
Member Posts: 265 ✭✭✭
My bottom drain plug in Bravo III will not turn out by hand. I am leery of using heat. Some online sources reccomend an impact screwdriver. Any thoughts?
This discussion has been closed.
Then use a large flat bit and pound that sucker out. Replace port and side drain plugs and put all new gaskets on the drains.
sorry
