Engine hatch motor failure
jme097
Member Posts: 1,224 ✭✭✭
does anyone have any ideas on how to get the engine batch open? Batteries are in and working but I think the motor for the hatch has failed. No fuses blown. Need to get the engine hatch open to check the motor. Any ideas would be appreciated.
Boat Name: Knot A Worry
If the collar can't slide, here's what happens:
You accidentally hold the button a moment too long, so the actuator starts pulling down on the hatch. This tension causes the gear to bind, locking the actuator. Then the only way to free it is to pull the pin and lift the hatch manually. Once you do that, it releases the tension, and then the actuator goes back to normal operation.
I bet you one dollar US that's what happened.
