Gimbal grease?
what grease do you guys use on the Zerk fittings on the gimbal? Is the Merc gimbal grease required or are there alternatives?
  • awhiresawhires Member Posts: 53 ✭✭
    I use general marine grade grease, unless I run out, then I use whatever is in the gun, I figure it's better quality than no grease! Lol
  • raybo3raybo3 Administrator Posts: 5,614 admin
    @awhires bad move using grease that is not marine rater. "Regular" grease will get hard in water and cause all kinds of problem. Marine grease on everything.
  • love2cruiselove2cruise Member Posts: 35 ✭✭
    How often or when would you know that greasing the gimbal housing is required?
  • Dream_InnDream_Inn Member, Moderator Posts: 7,942 mod
    Twice a year, about 6 or 7 pumps each is what I do.
    Don't tell your wife that Dream. Just sayin LOL!
    Oh man Handy you love living on the edge.........LOL
    Where are these zirk fittings at?
    Boat Name: Knot A Worry
  • aero3113aero3113 Member Posts: 9,827 ✭✭✭✭✭
    Don't forget about the grease fitting on the coupler also.
    If the gimbal bearing is in the water, he has bigger issues than the grease getting hard.
    edited May 2016
    Its also about the environment its in. I have seen stirring completely seized because the grease it not marine grade. Of course I am in salt water......
    Thanks Gang, I'm going to take Al's advice and get the Mystik Marine from the local auto parts store for $4.99. Thanks again.
