Help with Bunk set up
Just purchased a 2000 Fiesta Vee 340 and need to set up the bunks on my trailer. Wondering if anyone can give me some measurements.
    Try calling load rite trailers they helped me when I did my old 242
  • Wire2WireWire2Wire Member Posts: 4
    Thank you will give them a call.
  • rasburyrasbury Member Posts: 8,495 ✭✭✭✭✭
    Al, bless you...your talking to 3 year olds here...do what?
    edited May 2016
    my 2 cents don't let your transom hang past the end of the bunks as it puts too much pressure on it. I like to have the transom outer edge at the rear bunks 1-2" towards the front of the trailer - past the end of the transom. I cringe when I see a big boat stored on a bunk trailer with 3" of the transom hanging off the end...but then I am a bit cautious LOL
    BTW the gel coat/fiberglass guy I respect so much told me that improper calibration of trailer bunks and particularly roller trucks results in more hull hooks and deformations than he can keep up with.
    Al has some great advice above on how to set-up your bunks to avoid serious bottom damage.
    Another piece of advise the gel coat/fiberglass guy gave me was to loosen the bow and stern safety straps during long storage periods (of course in a safe manner) to avoid deforming the hull due to "pull down" stresses. Made sense to me so I did it.
    Post edited by Michael T on
    Thank you all for the help. I just had trailer modified so all bunks are adjustable.  Hopefully all will go well when I get there to pick her up.
    Thanks Again,
    When I adjusted the forward bunks on my trailer, I guesstimated at what they should be, loaded the boat then took a floor jack under the first bunk, loosened the adjusting bolts, lifted the bunk into the correct position with the floor jack and tightened the adjustment bolts - then the same process for the second forward bunk.
