Kohler 5ECD generator, exhaust smell gasoline and slight sheen on the water when running generator
" A couple questions. First, if you get close to the exhaust, can you smell gasoline? Not exhaust, but gasoline like when you are filling up your car. Second, is it running louder than normal? If you have these symptoms I may be able to help"
I have exactly this problem. What should be done?
Is it important to have OEM Kohler O2 sensor?
Fuel + oxygen + spark = ignition.
Starting with spark - you replaced spark plug, but is it getting a zap of electricity?
Fuel - injectors blocked?
oxygen - valves okay/lifting?
Thanks Ras!
Believe me, it was a lesson learned on my end as well. I actually carry a spare coil because I've heard when one goes, the other has a good possibility of going as well. Glad it worked out for you!
