Charger and fridge
1995 fv-265. Battery charger and fridge on same breaker. Worked last week, I pressure washed the engine compartment the other day now the breaker is tripped and won't reset. There is a battery isolator switch also. What / where do I start troubleshooting this??tia! - clear
A Lot of parts can get water ingress due to the pressure, and takes weeks to dry out , and or corrode and never work again.
use a multimeter and trace it from the source to the effected units... will take time...but has to be done.
Also check the alt wire on the alt itself. There should only be one wire coming off the hot side of the alt to the isolator. If you have the red wire leading to the starter than that could also be the problem (you could have sprayed it up to ground it on the engine block). From the merc factory the alt wire goes to the starter, but for 2 battery installations it should go to the battery isolator. On mine they ran to the starter and to the battery isolator.
I dont have the wire diagram online but do have a hard copy so I can do my best to help. contact me direct my user name at yahoo.com
Good luck
Steve
You might be able to save it by drying it out. Not sure the best way (hair dryer???).
for some reason my phone is not synching to the computer. here is a link for the generic wire diagram. you are looking for the single engine diagram.
The yellow wire box is for 110volt. it runs the wire to the battery charger
Its a silly thing to do in general.
Thank you to people who offered their insight to help me trouble shoot this.
And, before we do another lap of" never pressure wash the engine compartment" I heard you the 1st time. I already admitted it was a bad idea.
I get get on here to learn, share, and I try to help others, not interested in being shamed.
awhires, absolutely agree - no shaming here. Some of us older guys tend to repeat ourselves, please forgive us that! Since none of us is perfect - don't give up on us! It's a great forum and we all value your participation. This forum server doesn't have enough memory to list all of my mistakes. I just try not to make the same ones twice LOL
BTW your point of upgrading to today's standards applies to cars, houses...... what we try to do on the forum is point-out a past practice that might be harmful instead of just "the old way of doing things". We are more boater than diplomat sometimes! :-)
