Kohler 5e......what else do I need to change??
Soo many posts about problems with this generator. Having surging issues with mine...does it with or without a load. Here's what I've done, changed plugs, cleaned spark arrestor, changed fuel separator, put on brand new carb, put on brand new fuel pump.....What am I missing here guys?
On a side note.....I have a good used carb and fuel pump for sale!
vacuum leak
or fuel delivery
i worked on my friends same gen model last year.
rebuilt the car and had to adjust it under load.
put a new impeller in it
then had to replace the choke
his boat came from the salt so choke was rusted shut.
also make sure all tension springs are there and installed properly.
if not it wills surge.
easy way is to unhook the choke and manually open the butterfly to see if it levels out.
Make sure fuel pickup is not clogged and still there.
since it used a regular nylon tube that fits into the tank it sits so wen you are 1/4 tank gen will not start. That way it will give you fuel to start engines and get more fuel.
on that note carefully unscrew the gen pickup and inspect the pickup tube.
fuel pump is low pressure so if it fell off or has cracks it will starve the gen for fuel. On my buds boat I took the hose off and by manually starting the gen put the hose to my lip to check for suction.
had strong pull so it eliminates the pump
when I checked the fuel pickup there it was. Cracked tube that was partially broke.
there is no filter on it since they have a inline fuel filter.
