Holding tank sensor
does anyone know how to remove this cap? I believe it is the sensor to the holding tank. It isn't working and I would like to try and clean it to see if a i can get a reading on it.
Suggestion: if you have a pump-out facility that will let you hang out for a few minutes, do this: pump out, remove sensor, spray inside of tank with a hose, pump out again.
