Rinker320 hull specs
steevo
Member Posts: 23 ✭✭
I am building a trailer for a 320 that I am going to pick up in a month. Does anyone know where I could get some hull specs?
My trailer is 40' long with 18K capacity with torsion suspension and drum brakes on all six wheels with the piston type brake actuator.
There is a secondary set of bunks that supports the bow and then you have the bow roller support stanchion. It took a little adjusting to get the boat supported correctly and get the weight set correctly. What I did was I moved the stanchion as far forward as I could then set the two rear bunks all the way to the sides of the trailer (max width of the bunks) then lowered the front bunks down. I then loaded the boat on the trailer with the stern about 18" past the leading edge of the bunks. Then moved the stanchion forward to the bow eye, adjusted the bow roller up to where it met the bow eye, tightened everything down, put a 6" ratcheting strap on the bow eye to the trailer then slowly pulled the boat out. Then checked the tongue weight (kind of guessed at this - mainly looked at the truck to see how much is was sagging) and then took a floor jack under the forward bunks and lifted them up to support the bow section of the hull, tightened it up and took it for a short test. Had to do this process a couple of times to get it right but it was worth the effort since I can haul going around 70 pretty easily - not that I routinely haul that fast. Usually I go around 60-65 mph.
My tow vehicle is a 2003 Ford F-250 4x4 with the 7.3 Diesel - plenty of torque and power to pull my boat which is around 15K with fuel, etc.
http://www.mercurypermits.net/8-boat-us/6-welcome-boat-us-members
Yes it was,and the price was right for me. He had said that there was quite a bit of interest in it. When I talked to him January,I said "should I put a deposit on it right now? How many boats do you sell in the middle of winter?" Now that I have it home,cleaned up,polished, and ready to go in the water, I can see how good of a deal I go on it. The scratches that were on it all polished out,and the interior cleaned up like new. The broker,Don Allin, and the previous owner helped me load it up when I picked it up. Both great guys! Would definitely buy with that broker again.
