Trim Limit
aero3113
Member Posts: 9,536 ✭✭✭✭✭
Two seasons ago I had my trim pucks replaced. Today I was playing around with the boat and was looking at the drive. Does this look like the correct height for the limit cut off or should it be higher? Obviously I can get it higher with the trailer button but should I adjust the puck or is it set correct? I haven't had any issues trimming to the correct RPM.
Here's a link on how to properly set up your trim senders if anyone wants to check.
http://www.boatfix.com/merc/Bullet/92/92_12.pdf
