Wet Weight of 276 BR with arch and 350 mag
All,
Any thoughts on wet weight of a 276 Br with arch and 350 Mag? I have Toyota Sequoia with a towing capacity of 6500 lbs.
Thanks
Thanks
An acquaintance said his 2014 276 was close to 6800 pounds with gas and gear. Also respectful reminder - loads for tow vehicle ratings are for full tank of gas, minimum gear and one driver. All other loads - more passengers, gear etc. must be subtracted from the vehicle's published maximum tow rating.
You could easily be right. The gas on a 276 should be around 75-80 gallons? I bet the weight of the trailer was NOT in that calculation! That would add about another 1500 lbs?
What year Sequoia (just curious). I had a 2010 Tundra with the 5.7 (381HP) and the 4:30 gears in it. Rated at over 10,000lbs towing. Just surprised the "Tundra SUV" would take such a hit to towing capacity.
Now for my truck, I just got a 2016 F150 3.5 Ecoboost, 3.73 and max trailer tow. 11,500 lbs for me though since it's got every option and is a crew cab 4x4. -=Mike G.
2014 Rinker 260EC
Any pics of that truck? I sure do like the looks and amenities of the Ford, but back in 2010 when I bought my truck, the Duramax from GM beat all of them.
Patrick
