Installed trim tabs this weekend... I have a question
I spent about 9 hrs over two days installing trim tabs and the wiring on my 246CC this weekend. The project went pretty smoothly, but I was unable to test to see if they actually worked.
Here is the question... for those of you with the factory electric tabs with the self retracting feature, does the engine have to be running for the trim tabs to work?
The trim tab instructions for the wiring require a power/ground hook up (preety self explanitory) but then also require a seperate "signal" for the self retracting feature (I have the LED indicator swtches). If the signal is not hooked up correctly, the instructions say the tabs won't work. The choice for the signal can either be the analog signal for the tach (to see if the engine is running) or the on/off power from the ignition.
When I went to wire all the stuff, it looked like the standard Rinker wiring bundles had all the optional trim tab power connections already there. There was a connector for power with a 20amp fuse and a convienient conector for the tach signal. So obviously, I chose these connections.
After connecting everything, the tabs would not turn on, the only thing I could think of is that because I didn't actually start my motor (no tach signal?), the tabs won't work. The boat is on a trailer in an area where I can't get muffs on the outdrive.
I was going to try changing the tach signal to the ignition on off power, but I figured I check with everyone else first before I mess with it more.
So..for those of you with the factory electric tabs with the self retracting feature, does the engine have to be running (not just key in the on position) for the trim tabs to work?
THANKS!!
I wish it wasnt this way, as it would be nice to get inside the pockets and clean the grime & zebra mussels during the season. Maybe liability? So someone doesnt accidentally get a pinched (or worse) finger if they detract with a hand near them?
Mine are built into the hull, more or less.
I read somewhere that the only reason Lenco wired the tabs to the tach signal was that they were afraid they would violate a Bennett patent for their self retracting tabs if they also used the ignition power.
You have to move the orange wire from the Lenco control box from the gray wire (tach signal) to the purple wire (power from ignition on to gauges). Both of these wires are in the pigtail that plugs into the back of the tachometer.
I installed the Lenco w/LED switch and they retract as soon as the ignition is turned off.
Boat: 2004 232 Capitva CC
Boat Name: Mixed Nutz
