New 270 fiesta vee need help!!!
ok first, I am new to this forum and really would love some help. I recently purchased a 99 270 fiesta vee that had been sitting for almost 8 years in the previous owners back yard. I am not familiar with rinker boats so please bear with me. I am having trouble locating any of the seacocks. There are 2 pickups on the port side of the hull about 10 feet from the transom not sure what those are. The galley pump will run but not achieve a prime. If anyone know where I might be able to locate a owner/operators manual that would be awesome and might answer most of my questions.
Welcome to the board and congrats on the Rinker, they are great boats.
Cheers,
Patrick
As far as the galley pump, sitting that long the seals may have dried up. I have read all sorts of way to bleed the air out- I would start my checking the hose connections below deck. If I run out of water, to re prime I turn all my faucets on and hit the pump and it will eventually prime and start pumping water. Do a search on the site and other have various tricks they do with the filter and all sorts of things to get it flowing.
Welcome to the forum, you are required to put up pictures even if you do before or after. You will find all sorts of help here-there are some real knowledgeable people on here, some are mechanics some are tinkerers (like myself). Some of this stuff we can figure out, sometimes it will just have to go to a shop. Fire away with questions and everyone here will help you as much as we can. Mine is a great boat and could not be happier with my Rinker choice, good luck!
If the galley pump is pumping through, it's primed. So if you don't get flow with a little resistance, there could be something wrong with the pump. Check the connections, poor quality could lead to low amps, so the pump doesn't have the juice to turn. Inspect the casing, can you take it apart and have a look to see if it's been damaged?
