mooring cover snaps
rasbury
Member Posts: 8,736 ✭✭✭✭✭
as mentioned in another thread, I bought a used cover from a forum member and all is good with it, just have a lot of snaps to add to the cover! My old one snapped along the top edge window frame- this one goes over the top and will fasten along the bottom of the window-somewhere. I have to add the snaps but not sure where- should they be put on the bottom edge of the window frame or into the fiberglass past the edge of the window frame?
Best Answers
aero3113
Member Posts: 9,586 ✭✭✭✭✭
Does the window frame have slots to install snaps? Once in they slide to the correct position. No need to drill holes.2008 330EC -
rasbury
I will look, there is a rubber trim, perhaps it covers up a slot..im having a heck of a time finding plane snaps...much less something like what your describing! My other snaps on the window are screwed in. -
rasbury
Well, stand corrected,there are slots for the snaps but only at the top. There is a very wide slot along the bottom, it's pretty deep and holds trim, more of a channel. I did not wants snaps where the front glass opens to step or trip on...any other way, drilling gel coat I don't like.
