Engine problem!! Help!
Good morning forum!
Tried to take the boat out yesterday afternoon in order to test everything out and check systems. Everything seemed fine, both motors ran well at idle, got up to operating temp, nothing was leaking, okay I thought, I must be good to go! Left the dock and after idling out of the cove, pushed the throttles forward, ran fine at 2000rpm for about 2 minutes then tried to push them up to get on plane, the port motor originally hesitated then revved up to 4000 or so, then stumbled, sputtered and died. Re-started it, let it idle for awhile, then same as above. This happened a few times, now it won't start at all. I thought maybe I had bad gas, but the port and starboard tank gas are the same age, starboard engine runs fine, I never use ethanol gas. Genny runs fine. I pulled the brand new fuel/water separator, looks fine. It's obvious I have a fuel issue, but I need help to narrow it down.
I have on/off valves on the fuel lines going to both tanks, I have always left them all wide open, can someone tell me how to isolate one tank? What are the symptoms of a fuel pump issue? Didn't I read somewhere on the forum that the fuel pumps have a little screen in them? Anything else I check before I start buying random parts?
Thanks in advance guys!!
a blown regulator could certainly explain the uncontrolled rev- metering the fuel to the injector/cylinder depends on steady predictable fuel pressure...
you can pull the regulator off the running engine and put it on the down engine and see if the issue resolves/follows...
you may be in the market for a fuel pump...
I have the ability to switch tanks around, but there are like 5 handles in there and I don't know for sure which ones to close in order to isolate one fuel tank....are there any pictures or threads I could read to figure that part out?
again, swap the pressure regulators between the engines... if the problem follows, then there you have it.
MPI is fairly simple... known 'duty cycle' or how long the injector opens it's gates... known metering of fuel delivery based on size of injectors and pressure behind the gate... a bad regulator allows too much or not enough fuel past, either of which can cause a no start.
you said it went from 2k to 4k and then died, after hesitating and after applying throttle... you said it did this several times before finally not starting...
you need to do the easiest thing first, and that is check the actual fuel pressure.... rule it out... it HAS to have suitable pressure to run... after that checks out, and I wager it will, move to spark and run through that, which is where I think your issue exists... a crank position sensor (ckps) will do this just as you describe. They generally misbehave at higher RPM's first, and then altogether. The CKPS is how the engine knows to trigger spark, where the cam position sensor (cps) is how it knows to trigger injection...
also, a gross vacuum leak could be the culprit... you said you swapped TB's... check carefully for a vacant port.
So, after replacing the following, I am no further along than when the problem started, hopefully someone can help me out. Symptoms: Sometimes will run on the hose at idle perfectly, most times has a surging idle, then it just doesn't start. I will layout the things that have been fixed or ruled out. Reminder: VP 4.3Osi EF version.
1. Replaced the entire throttle body assembly and both sensors (IAC and TPS), fairly pricey but found an almost new used one on ebay.
2. Drained fuel and replaced with new, (lots of $$$)
3. Replaced spark plugs
4. Replace the filter on the fuel pressure regulator with the clip according to the bulletin from VP
5. Swapped fuel pressure regulator from good engine to bad, no change in symptoms.
6. Thoroughly cleaned the flame arrestor, it was pretty dirty.
7. Did what 212 suggested and got a fuel pressure gauge, checked pressure, had zero on the low side pump, high side was okay. Replaced fuel pump ($$$$). After replacing fuel pump, (Wednesday night in the dark) initially the engine started up and ran on the hose on Thursday afternoon, purred like a kitten, let it run for about 15-20 minutes, all seemed to be good to go. Went to put boat in water on Saturday morning port engine started but did that scary surging idle between 1500-2300RPM, let it do that for about 3 or 4 minutes, then shut it off. It restarted after a few minutes, idled nicely for about 2 minutes, then died, wouldn't start again.
8. Pulled a spark plug, (it seems pretty dirty for a brand new plug), grounded against the block and cranked it over, I did not get a "regular" spark, but I did get one nice bright one in about 10 seconds of cranking the engine over. I might have not had a good ground so I am currently not putting very much faith in this test.
After consulting a family member who used to be a mechanic he said it could be coil, they can go bad intermittently and potentially cause the surging idle, and no start condition. The only surging idle situation I have ever fixed was resulting from someone setting the timing wrong. But we have not messed with the timing, as I wouldn't know how on an MPI engine. Going to try to pull coil from good engine and put it on the bad engine to see if changes anything. After that, about the only thing I can think of is the actual set of ignition wires, plugs and coil. Although I have looked them over, and they don't seem worn at all. Engine only has about 350 hours on it.
What else can it be? Al, have you seen anything like this? I would take it to a shop, but they are so backed up this time of year, I will be lucky to see my boat before summer is over, not too mention I hate taking it in if I don't know what to tell them to replace, that has a tendency to get expensive as they throw parts it just like I would. I have already spent almost two grand and this has got to be something simple because the engine does run, sometimes. Any help, or advice you guys can provide would be GREATLY appreciated.
i personally replaced some that were broken in half or split in the middle causing low vaccum. Some even have screen filters on them.if you have two ya ls try running on the other tank.
i would check the timing for sure.
if she starts and runs then firing order should be good. Check coil and check compression next.
also check that leads to the fuel pump are good and providing good voltage.
I did see fuel pumps go bad out of the box for many different reasons. So double check the fuel pressure again.!
I would try switching TPS and IAC for motor to motor. Not sure if this is when your problem started but start with where problem started. I replaced dist. cap, plugs, and plug wires last year and then it had a midrange miss. Took to my dealer and he finally replaced cap, plug wires, and plugs. Probably one plug wire with issue even though it was new. Just a thought.
Rob
see if you can start the engine, let it idle while carefully spraying (in really short bursts) around the throttle body, and then around the perimeter of the intake manifold... if or when you have a surge in RPM's, you've found the vicinity of a vacuum leak...
it may be sealed sufficiently on a cold engine, but when the engine warms it may be pulling unregulated air...
they generally have an epoxy fill around the coil (inside the casing, obviously), and often have imperfections... when they warm, the imperfections turn to cracks... after they've cracked for a while, and while on a warm engine, they'll separate- and often stop functioning.... until they're cool again, where the cycle begins all over again.
Thanks, I was thinking plug wires next. I am unfamiliar with the distributor set up on my engine, but replacing the wires should be easy enough.
Patrick
you know what, though? take the COIL ignition wire off one engine and put it on the other, and see if that is your issue... I've seen the filament flat out rot... and that center coil wire (follow coil to dizzy cap) see's six times the fire as the other ones... if one is worn, it's that one...
your described issues are consistent with that coil or that coil wire being bad... If it's been a while, that could be it for certain.
Good stuff. I will change that out tonight.
dalek,
I can try that, if I can get to run. Sometimes it starts, most times not.
Thanks!
Patrick
wires will show no spark or a weak spark
easy test
it's the non-requested increase in RPM that has me tilting my head... sounds like uncontrolled induction of air, and nothing to do with spark... the rest of it sounds like spark...
t/s'n through the interwebz is difficult at best... no?
Al,
My distributor cap is strange looking, I am assuming it's all electronic on the inside since it's a 2005? If it was like the older ones, I would have swapped it out already. Engine electronics intimidate me, mechanical things not so much.
Thanks for the tips...I will update asap.
Patrick
in my experience, a cracked cap will do the opposite- they are a BEAR to get started when there is moisture in the cap, but when the moisture burns off they're fine (fine'ish)... just to cause you grief next time you try to start cold... that said, it could separate all the same.
