2003 Fiesta Vee 270 Air Conditioner
SteelersTNT
Member Posts: 11 ✭
I am new to this boat, I don't have any manuals and I wanted to ask if anyone had info on the Air Conditioner, diagrams, startup, use , winterizing, ect. I specifically wanted to know what I should check on it this year for the first time start up, any valves or things to check and where they are located. Any info will be appreciated.
Welcome to the forum, if it's a dometic, this may be the link you need:
http://www.dometic.com/QBankFiles3/EPiServer/Dometic/US/Manuals/Marine-manuals/Air-Conditioning/Controls/2231-Marine-Air-Passport-Control-Operation-Manual_21429.pdf
Also, make sure the seacock is open for proper water flow. You may have a separate breaker for the pump as well that will need to be turned on.
On a side note, where are you docked at? I am a Pittsburgh guy myself. There are a few of us on here.
06 Rinker 270
06Rinker270 - when you say haul out, do you winterize? If so, those lines need to be emptied.
I keep mine open when we haul and the system drains. I normally don't have any issues getting prime when I splash her, and drive over to my slip.
06 Rinker 270
I have always left the valves (3) open after winterization, although theoretically the entire system should be full of AF so why not close them? Good question.
Seacock will be under the aft cabin sump under the cushion.
Here is the manual
